Porterhouse 12 Posted January 18 Share Posted January 18 Hi All I have the dreaded deteriorated sunroof gasket (made worse with the recent weather) I understand that this is a complete glass/seal replace unlike say a GS450 where you can buy the seal OEM 6325130100 on its own. You know what I'm gonna ask has anyone tried to fit a OEM 6325130100 onto an LS600 or 460. Are they even the same size? Welcome your help on this one Quote Link to post Share on other sites
LexusRbest 5 Posted January 23 Share Posted January 23 The sunroof seal is a knock on trim that is often bonded on to the metal with sikaflex type mastic at the factory. it is like a miniture flocked version of a door seal it doesnt seal as such ,it just stops the worst of the weather getting in to overwhelm the drains. I haven't compared models but would expect all the Lexus models with a tilt and slide type sunroof of that era to use the same seal. there is a recall on webasto manufactured sunroofs in this style due to the glass delaminating from the metal sub frame on lesser makes like mercedes and ford ,.......hopefully toyota didn't copy that bit. try a sunroof specialist for a length of seal or a breaker for a better bit 2 Quote Link to post Share on other sites
ambermarine 726 Posted January 24 Share Posted January 24 Paul frost as a 460/600 sunroof for sale which according to his listing on Ebay fits the 600 . 1 Quote Link to post Share on other sites
Porterhouse 12 Posted January 25 Author Share Posted January 25 Thank you very much for your comments guys. I might just try buying a seal and see what happens. It seems such a shame to get rid of a perfectly good glass unit because of a seal that does come off so another could be refitted. I'm encouraged that it isn't the part that really keeps the water out as David explains above. If a new seal works then other LS owners will have confidence to try I also tested the drains & all four work so very pleased 1 Quote Link to post Share on other sites
ambermarine 726 Posted January 25 Share Posted January 25 1 hour ago, Porterhouse said: Thank you very much for your comments guys. I might just try buying a seal and see what happens. It seems such a shame to get rid of a perfectly good glass unit because of a seal that does come off so another could be refitted. I'm encouraged that it isn't the part that really keeps the water out as David explains above. If a new seal works then other LS owners will have confidence to try I also tested the drains & all four work so very pleased You may have to live with this glass as the replacement quote from amayama is nearly $600 + duties shipping etc. The parts breakdown shows the seal as part of the product and not obtainable as a separate item so it might not be a good idea paying out good money for a seal that does not fit. 1 Quote Link to post Share on other sites
PJ Murphy 14 Posted January 25 Share Posted January 25 The previous owner of my car dealt with this problem by using a national windscreen and glass company however I can’t find the receipt. May be worth a phone around. Quote Link to post Share on other sites
Porterhouse 12 Posted January 25 Author Share Posted January 25 1 hour ago, PJ Murphy said: The previous owner of my car dealt with this problem by using a national windscreen and glass company however I can’t find the receipt. May be worth a phone around. Gonna try that Paul. If you do find info be much appreciated Quote Link to post Share on other sites
LexusRbest 5 Posted January 25 Share Posted January 25 I have been successful in this respect . Autoglass repair glass breakage..... If you do it yourself you will need to remove the glass panel to fit the new seal. while it is out use tissue or kitchen towel to dry the joint between glass and metal subframe and apply a bead of polyurethane sealant like sikaflex( now available from screwfix) between the two on the inside edge of the metal subframe, just in case they did copy webasto............ 1 Quote Link to post Share on other sites
Porterhouse 12 Posted January 25 Author Share Posted January 25 8 minutes ago, LexusRbest said: I have been successful in this respect . Autoglass repair glass breakage..... If you do it yourself you will need to remove the glass panel to fit the new seal. while it is out use tissue or kitchen towel to dry the joint between glass and metal subframe and apply a bead of polyurethane sealant like sikaflex( now available from screwfix) between the two on the inside edge of the metal subframe, just in case they did copy webasto............ You little beauty. Will speak to Autoglass see if they will attempt this many thanks David Quote Link to post Share on other sites
