Need some urgent help guys!!! The horn in my CT200H has stopped working intermittently. It only works when I press the horn whilst the steering wheel is slightly turned in either the 2 o'clock or 10 o'clock position but doesn't seem to work if my steering wheel is dead straight. No warning lights on the dashboard. Only noticed this today and it worked fine straight after I retrofitted my cruise control switch on my steering wheel a month ago.
i'd check to see if there is a relay for the horn as it may of started to become faulty
or the clock spring cable thats behind the steering wheel, the CC plugs into the clock spring unit        the cable maybe part of the switches.
here is a link for your to try :- https://www.synetiq.co.uk/
Been reported many times on Lexus US forum that it,s probably the clock spring behind the steering wheel as already stated.Seems to be a common problem on these.
