How to adjust 450h air suspension
Hi all,
I'm looking for some help to adjust the suspension height offset on my 2010 RX450h SE-L with air suspension using Techstream, I did raise it about 20mm to try and level it but it is now not level and too high and i want to lower it, it seems a bit hit and miss so I am hoping someone can help with the correct sequence to adjust the height. could someone also give me the standard ride height for the car?
any help much appreciated.
15 hours ago, alanann said:
I found some old posts in the LS forums with the info I needed so I have managed to get my suspension sorted.
Oh well done, Alan, I wonder if finding the information on the forum's 'search' facility was more difficult than sorting out your suspension (!?)
(I've no experience of Lexus air suspension - so would have dared to advise!!!!)
  • 2 years later...
  • 3 months later...
just measured my rx450h on air suspension and all four corners are 46cms from wheel arch to centre of wheel
hope that helps
