changing exhaust manifold
This may help from the manual
15. REMOVE EXHAUST MANIFOLD
(a) Remove the 3 bolts, retainer and nut holding the front exhaust
manifold to the front exhaust pipe.
(b) Remove the 2 bolts and exhaust manifold stay.
(c) Remove the 6 bolts and 2 heat insulators.
(d) Disconnect the 2 oxygen sensor connectors.
(e) Remove the 8 nuts, exhaust manifold and 2 gaskets.
16. RHD:
REMOVE STEERING SLIDING YOKE - this is the connector bracket/joint between the steering column and the steering rack
