Noise filter Fuse???
3 hours ago, twin2urbo85 said:
I have been replacing some fuses as needed
That's a very worrying statement!
Fuses only need replacing if they blow, and they only blow due to a fault (with maybe a very, very, occasional exception) and even then, usually only one circuit or fault at a time, so how come you're replacing multiple fuses?
On 3/26/2022 at 3:13 PM, J Henderson said:
A quick Google suggests its to do with the radio antenna. Probably reduces hiss/ interference.
Wait what? Where is this fuse located? Could this be the cause of the radio losing signal when the rear demister is on?
