The Battery has finally given up the ghost, a few different manufacturers list different batteries, What is the correct ampage and cranking power, some say 50/500 and others say 100/700. Will probably go with the 100/700 but had to put the smaller one on for now as couldnt source one over the bank holiday!!
My 2000 MkIV has this one:
Model Code:X00004-00011-90
Battery, 80D26L-MF, 70AH
Battery Type 80D26 L-MF
Volts 12
Capacity (Amp Hours) 70
CCA (Amps) 630
No. of Plates 13
Length (mm) 260
Width (mm) 176
Height (mm) 222
Weight Empty (Kg) 12
Acid Volume (l) 4.3
If memory serves, it's a Panasonic.
