Dealer only personalised settings?
Ruffle
4 minutes ago, Ruffle said:
Does the LC have any 'dealer only' personalised settings? Is there a list of them anywhere?
If so, who had what changed?
It's all listed in your handbook under Customised Settings. It shows those that the driver can change and those that must be done by the dealership
Download a copy from the Lexus website and have a good read before your car arrives 😉
Doh!  I did look there before posting but they've spelt Customisable with a Z so my search of the PDF failed to find anything.
Ta.
Ta.
That sounds about right for the standard of Lexus documentation. In this case we could cut them some slack and says it's the american-english spelling. Something I find irritating in the extreme 😠
2 minutes ago, malcolmw said:
Carista can alter most of the so-called dealer settings for a quite  modest outlay.
Thanks. However a quick speed read tells me there's only Window control from the key fob and disable the alarm with the mechanical key that I'd want changed (if I've missed something else that's a 'must have' then please shout out).
Something for my dealer to do before I collect on Monday :) :) :) :)
I found this:
https://caristaapp.com/vehicles/lexus/lc/1st-gen
but a lot of the things listed are normal settings that can be changed without dealer intervention.
There there's the 'Beta' version that lists more function but a lot seem duplicated with the non-beta version:
https://caristaapp.com/p/toyota-uds
One would need to do a side by side list to see what's only available through Carista. It isn't expensive (especially if you already have a Bluetooth OBD2 adaptor).
