Intermittent misfiring
RK1975
You may have seen this thread so apologies if so but the symptoms on here sound same as yours - culprit EGR:
If you do a Google search on your symptoms for CT 200h or Prius (same mechanicals) then lots of threads about the EGR being the culprit of your symptoms at your sort of mileage.
@LexusDavesuggested EGR but you said the RAC said it could not be that - IMHO I would take what the RAC said with a pinch of salt when you see all the posts pointing to EGR and consider getting that cleaned as a first step in logically troubleshooting your problem - much more likely culprit than the flywheel.
