NX450H 2023 Time lapse / Ave speed reset
Would welcome recommendations / suggestions if anyone knows if it’s possible to reset the time lapse / ave speed after each journey ( it  is displayed in the combination metre section ) It seems just to total the full hours the vehicle is driven and not very useful if it doesn’t reset the time of each individual journey as per Camry or other Toyota / previous Lexus models.
Many thanks
The only way I've found to do this is to reset the trip info which resets all of the data.  Click on the car icon on the main screen and then trip info.  The is a "clear data" tab.  When I did this it took over 30 minutes to clear all data so I ended up locking the car and leaving it to reset which worked fine
Great, I will try that, thank you as it’s a feature I’ve used in previous models & it generally reset once you start a new journey. I think Lexus for some reason have complicated this feature so I appreciate your suggestions.
  • 7 months later...
I have only found one way to clear all the info, and that is to reset the trip details.  Click the car icon on the main screen to get trip details.  The "clear data" tab is still there.  I let the vehicle reset itself after waiting over thirty minutes for the data to be erased, and it worked perfectly.
