Automatic interior lights problem
Hello 👋🏻
Last night I discovered that my automatic dome lights don’t work properly on my IS300h. When I unlock the car, open the front/rear Doors or go past the car the dome lights should be on but they don’t work. I can turn them on just manually. I checked for being activated the switch and I saw that is working properly only the lights from the doors courtesy and the lights from the legs.
I checked the DOME fuse and is fine. Someone know what the problem is?
Thank you!
In my RC there is a switch in the overhead console that disables the interior lights from coming n with the doors opening. Could it be that the IS has this and it has been inadvertently switched off?
It’s enabled because the lights from the legs works when the door is open or the car unlocked. Just the dome lights don’t turn on automatically just manually…
