Replacement rear upper control arm nut?
Trying to swap out my differential and derust all of the rear end today and i managed to damage the upper control arm nut (The 19mm large washer nut) to the point i can't tighten the ball joint back up fully. The only nut i can find is in the USA https://www.ebay.com/itm/152449881061 I can't seem to find this anywhere in the UK or i'm so stupid i'm searching for the wrong thing.
Can i use any M14 1.5 nut with a washer for now? Will i need to replace the entire balljoint on that control arm? (It the top central arm of the rear wheels)
This is the nut i've linked but just incase the link breaks or gets taken down here's the picture.
Picture 4 of 7
Picture 4 of 7
lexus dealer. i was able to get new front strut bolts and nuts from them as mine were rusted on and i had to cut the old ones off.
