Headlight Clear Lacquer
Boomer54
  • 3 months later...
On 9/25/2023 at 10:05 AM, Boomer54 said:
Quick shout out. Anyone got a particular brand that has impressed with it's brightness and longevity?
Hello Boomer54,
I dont use  lacquer, but wd40 spray on the lens and dry off
Have heard that this product works, not tried it myself as have used the WD40 mainly or a silicone spray.
The trick is the binding of the coating to the lense so that it does not peel of (wear out) and having tried cheap products never seemed to be worth expense over using WD40 and just using T-cut (or some such agent - ceramic bath cleaner) on a regular basis to clean the algal growth off the headlights that lives in the micro-scratches and causes the dimming.
  • 4 months later...
Cut and polish the surface with a D/A polisher and some 2300 grit polish, clean and then apply some CarPro CQuartz ceramic coating.  Lasts up to 3 years and not too expensive.  Also does the bodywork.
