Beep When Turning on Engine
JamesP33
Hi!
Can anyone help! There has recently started a beeping noise that lasts for about 5 seconds when I turn on the ignition in my 2005 Lexus IS250 that has only just started. I cannot work out what is causing this - I heard that this could be due to the Battery needing replacing? Does this sound right or could there be something else at play?
Any help is appreciated! 🙂
James
4 hours ago, JamesP33 said:
Hi!
Can anyone help! There has recently started a beeping noise that lasts for about 5 seconds when I turn on the ignition in my 2005 Lexus IS250 that has only just started. I cannot work out what is causing this - I heard that this could be due to the battery needing replacing? Does this sound right or could there be something else at play?
James
could be key Battery
Have a look at the info panel between the speedo and rev counter. There may be a warning/alert indicated.
For example .... you might see
  • Key Fob Battery low
  • Low Windscreen Washer level
These warnings are announced with a beep sound and the first time it happens you wonder what on earth is going on.
Hi Normski,
Appreciate this!
I did check all of the displays for any error messages etc but nothing was showing. I did some more research and I thought it may be the car Battery so am having it changed today but then I read more and think this is just the key fob Battery so will replace that too and hopefully should sort it!
Thanks again for the support! Much appreciated!
