Mossy's SC430
Mossypossy
2 minutes ago, Mossypossy said:
This is a wee bit different moulding than mine. More of a ridge runs across mine above the red circles.
This is getting very boringworthy!
Try fitting it without that grey panel in place …just to see how it looks 👍🏻
8 minutes ago, Mossypossy said:
It fits and the boot closes. Job done.
Will make the template when I find some cardboard.
Cardboard is the way to go as you only one chance with the grey mat 👍🏻👍🏻
if you want to go the full hog…here is some edging trim .
https://www.ebay.co.uk/itm/222964224068
Looking to replace all 4 shocks next. After consideration I think I will not be going down the coilover route.
Best price I can find for genuine Lexus shocks is here.
https://www.yam6carparts.co.uk/genuine-lexus-front-shock-absorber-lh--rh-48510-80423-12972-p.asp
Anyone know a cheaper supplier?
And what trade price does LPD give to garages?
Front SKU 48510-80423
Rear SKU 48530-80244
This company seems a good price, although I’ve not used them.
https://www.mlperformance.co.uk/products/genuine-lexus-48530-80244-superseded-from-48530-80352-sc430-rear-shock-absorber
many of the overseas companies can’t send shock absorber by aircraft as they are basically a pressured tube 😮
9 minutes ago, Mossypossy said:
And how many hours garage labour?
4 shocks plus front brake pads.
Hour per side for fronts, bit longer on the rear as all the boot lining has to come out first .
pads 1/2hr.
22 minutes ago, Mossypossy said:
See if I can get it done for a grand all in
You could if you buy some spanner’s and a socket set 😉
…Good to see so many alternatives to buying from Lexus 👍🏻
M25 and M11 joy today, and some rain. 280 miles so getting used to it now. Comfy high speed cruiser, no wobbles or vibrations. Collected even more stuff for the big clean up.
Glad the SC is getting your seal of approval now, they do munch up the miles very easily 👍🏻
5 hours ago, Mossypossy said:
Obviously when I put the radio on the antenna refused to retract after happily deploying!
Some pics after a bit of a wash.
Long shot, but have you checked the TA button is off.
