Possible steering issue
N13GEY
I've a 2009 RX450h. I recently managed to hit the kerb at a local pinch point. I knackered the  nearside tyre and damaged the hydraulic damper. I replaced both items. I've had the steering checked for alignment, had it corrected and a report printed. All good. The steering I feel is best described as "woolly."
I suspect that something else is causing that "woolliness" Any ideas? Could it bee the steering box? PS I've asked my local Lexus Centre and they can do a diagnostic check for which I consider I'll need to save up! Thanks in advance
Not a steering box as the RX doesn't have one as it uses rack & pinion steering - so could need a new rack (which you won't want to purchase new from Lexus). I suspect there are some bent steering/suspension components which hopefully would be cheaper than replacing the rack but I would have thought that would have been spotted when they did the alignment.
If you don't want to take it to Lexus you should be able to find an independent that can put it on a lift and check all the suspension, steering and hub components for play and damage.
