Skip to content
View in the app
A better way to browse. Learn more.
Lexus Owners Club
A full-screen app on your home screen with push notifications, badges and more.
To install this app on iOS and iPadOS
  1. Tap the Share icon in Safari
  2. Scroll the menu and tap Add to Home Screen.
  3. Tap Add in the top-right corner.
To install this app on Android
  1. Tap the 3-dot menu (⋮) in the top-right corner of the browser.
  2. Tap Add to Home screen or Install app.
  3. Confirm by tapping Install.
Door mirror not lowering when reversing
Featured Replies
Hiya i'm back again, my lovely Nx300h doesn't lower my mirrors when reversing, I hear a strange hydraulic noise when reverse gear is selected, and I think it should operate my door mirrors, but doesn't, why else would it make this sound, and also makes said noise, when taken out of reverse. I know it's there somewhere 😂🔎
I have not had my NX long so I’m no expert but put the car into reverse with foot on the break and adjust mirrors to where you want them and when done set memory.
There may be a setting somewhere in the myriad of options I cannot remember but I had a similar problem and found a post on how to do this.
Robin
If your NX is anything like my UX. To get the door mirrors to dip when selecting reverse, the door mirror controls need to be set to adjust the left or right side mirror. If the controls are set to the ‘neutral’ setting, the mirrors don’t dip.
It’s a bit of a weird annoying way to control this behaviour. You think it would be a car setting within the infotainment panel.
Make sure the door mirror switch is down on left. Select reverse, adjust mirror to desired tilt, take out of reverse, mirror will return to normal elevation. Next time you go into reverse mirror will adjust to what you selected. Switch to select left mirror adjustment should remain depressed. If you switch it to the right position left will not tilt.
Mirror switch is normally on the door. As said, ensure the left mirror switch is selected.
Good luck 😀
  • Author
Robin
Thanks Robin, tried and failed 😕
  • Author
Thanks DWRUK, tried and failed 😕
  • Author
Thanks eggie, tried and failed 😕
  • Author
Good luck 😀
Thanks scotlex, tried and failed 😕
Is this a new car for you?
Or have you had the car for a while and the mirror lowering function has stopped working?
This is the instructions from my manual which agrees with previous posters.
When the mirror select switch is in the “L” or “R” position, the outside rear view
mirrors will automatically angle downwards when the vehicle is reversing in order to
give a better view of the ground.
To disable this function, move the mirror select switch to the neutral position (be-
tween “L” and “R”)
With the shift position in R, adjust the mirror angle at a desired position to set the
mirror angle used when the vehicle is reversing.
The adjusted angle will be memorized and the mirror will automatically tilt to the
memorized angle whenever the shift position is shifted to R from next time.
The memorized downward tilt position of the mirror is linked to the normal position
(angle adjusted with the shift position in other than R). Therefore, if the normal
position is changed after adjustment, the tilt position will also change
Robin
I Have same Car same Year.. This Facility is not Available on This Model..Hope that Helps..!!!
I did wonder about this.
Thanks 😀
Note: Your post will require moderator approval before it will be visible.
Join The Independent Lexus Owners' Club
Our community has been built by enthusiasts, for enthusiasts, and proudly run by Lexus owners' for over 25 years. As an independentnon-official club, everything you’ll find here, advice, support, and opinions, comes directly from members with genuine Lexus ownership experience. By being a member you can gain access to active community forums, videos, news, events and more...
JOIN OUR COMMUNITY NOW!
LexusOwnersClub.co.uk (“Lexus Owners’ Club United Kingdom”) is an independent, third-party enthusiast forum created for owners and fans of Lexus vehicles. We are not affiliated with, endorsed by, or in any way officially connected to Lexus USA, Lexus Canada, Lexus UK, Toyota Motor Corporation, or any of their subsidiaries, affiliates, or authorised dealers.
All content, discussions, and materials posted on this website are generated by users of the forum and represent the opinions and experiences of individual contributors. Such content is not reviewed, approved, or endorsed by Lexus Owners Club, ACI LTD, Lexus UK, Lexus USA, Lexus Canada, Toyota Motor Corporation, or any related entity.
LexusOwnersClub.co.uk makes no warranties regarding the accuracy, reliability, or completeness of any user-submitted information.
Any reference to Lexus trademarks, logos, or brand names is used solely for identification and informational purposes. This site does not claim any ownership of Lexus intellectual property.
For official information about Lexus products, services, and corporate communications, please visit the official Lexus website relevant to your region.
Background Picker
Customize Layout
Account
Navigation
Search
Search
Configure browser push notifications
Chrome (Android)
  1. Tap the lock icon next to the address bar.
  2. Tap Permissions → Notifications.
  3. Adjust your preference.
Chrome (Desktop)
  1. Click the padlock icon in the address bar.
  2. Select Site settings.
  3. Find Notifications and adjust your preference.
