  • 8 months later...
Randy, you might want to try to disconnect your Battery for like 15 min or so to reset your ECU.. That might to the trick instead of bringing it to the dealer to reset it...
And Manib, I have a 02 GS also and my airbag light doesn't come on unless I turn the key without starting it... That's normal but if it stays on while the car is running you probably have a problem with the wiring or something... Get it checked out..
