Sign in to follow this
dandybear
1995 Ls400 Juddering At 30 - 50 Mph Ish
My Ls400 seems to judder after accelerating to 30-50 mph when I lift off the gas gently to resume a cruising speed.. It feels quite severe and i do not know if this is a common problem, but I have seen this before in a 93 Lexus Ls400, but I never knew what could be causing it. It feels like I am applying and releasing the brake pedal very quickly. Does anyone have any idea what could be causing this? Thanks,
Dan.
Are you sure you are not resting your foot on the brake pedal.I understand that juddering is a common problem on mid to late Ls400 but is not a issue with the mark 1 due to a superior build quality.I am sure some fellow members will be able to help you.
