I think you will find that it could be the heater stat has blown,not sure where this is located but on most cars at rear of glove box area.If you swich to manual and the blower only works at high I would say that is your problem.Had the same problem on one of my cars(not Lexus).
Thanks for the comment. I will check out the heater stat as the blower only works on high when switched to manual. A local Lexus service advisor has suggested the problem my be a blown Resistor Block associated with the blower. Any thoughts???
