Vacuum (negative ) Pressure Value
Rob
The other variable is engine condition. You will see lees vacuum as the engine wears out.
We haven't had the need to know, so can't answer that - sorry.
Maybe try dataloging your car via the OBD port?
The FCON ecu's have built in data loging to monitor most of the parameters under all conditions.
Why do you need to know anyway?
