Is200 Audio Amp
HI GUYS
I have a 2001 IS200 and I am changing the Bog Standard Audio system! I am wondering if someone can tell me if there is an OEM audio AMP in my car seperate to the double DIN unit I will be taking out. My car is not the SE model or anything just entry level.
I need to know this for the install of a Kenwood in dash multimedia system(KVT-725).
HELP :unsure:
I thought all models had a seperate amp?  :huh:
Maybe worth scouting through the audio forums:
Click here
I've  moved this into that forum too.  ;)
If I am putting in an aftermarket Kenwood system, the KVT-725, do I need an AMP? it says it has 4 x 50W output. Is this enough since I hear the IS200 has 8 speakers 2 in Front doors, 2 Tweeters behind wing mirrors on inside, and 4 on back shelf?
Umm... it all depends on what you have. Im no expert maybe someone can confirm if the following is true.
S is a basic model and I don't think you get 8 speakers.
SE and Sport models come with the amp and 8 speakers, basically its meant to be an all round system. I have a sport, and its a bit of a hassle to change my standard unit becuase I have to get a new rear speakers and new speaker cable, something about the speakers and amp are not standard.
But as mentioned above, I don't think the S has any of issues. but once again, you should check the ICE forum.
Ok I think I may only have the 6 speakers then! Cos I can only see 2 on the back shelf and when i go into the boot and look up I can see the backs of 2 speakers only! So If that leaves me with six 4 + 2 Tweeters will this 4 x 50W unit power them? Would I be leaving out the tweaters or something?
