LOWERING ADVICE NEEDED.......
uzziz
Hi all
I wana know if i should lower my is200se 30mm from the back at less maybe 25 or 20 mm at the front as at present the car is lower from the front so if i rplace my springs with Eibach 300mm lowering springs would the car still be more lowered at the front????
What would you recommend???
Any suggestions, ideas, thoughts, opinions.....:bounce::P:cool:
If you fit 30mm lowering springs all round the car will still retain it's slightly biased forward stance.
30mm is a good start off; it's the lowest recommended with springs only.
If you want to go lower you will need to get coilovers.
Remember when you lower, that if you want to change your wheels this shall affect things also.
This link will help for that. http://www.teamlexus.co.uk/forums/viewthread.php?tid=320
Mark,
That's exactly what I thought when I got a HKS set for my '01 Sport. However, the drop was measured at 50mm all round and now the shocks easily run out of travel when taking relatively sharp bumps on the road. I think I'm just gonna get the coilover set and replace the entire lot.
Hi all,
I have ordered H&R lowering springs with a drop 0f 35mm at front 35mm at the back, but all of you guys are using Eibach springs witha drop of 30mm, what do you reckon to these springs? and will the standard shocks be allright on this drop of 35mm?
