Road Angel 2
I've run a 12V feed from the lighter to a small socket in the 'lint tray'. Cable access is easy with the top tray removed. Remove the gear lever surround (lifts out) to give access to the wires at the back of the lighter. Note that the Pink wire is +12V.
1/2 hour job (including finding the tools!)
My snooper is hardwired to ciggy lighter as well
Cable runs from back of lint tray, down behind stereo and in at back of gear lever surround. Removal and access to behind stereo is a doddle, there's plenty of articles relating to it if you have a search
A little bit of jiggery pokery with the lint tray and you can make the installation look pretty tidy
