Sc 400 Vibration Problem-help!
dan83
hey all this is my first post, just got a sc 400 yesterday. here are the specs and problems so far:
1992 lexus sc 400
129k
timing belt changed at 67k ( but in 1997 i might add)
tires are worn badly
MOST SEVERE PROBLEM: Shakes BADLY at 70-75, when not accelerating, let me explain.
It does NOT vibrate when revving in neutral when not moving, does not vibrate when accelerating hard from 0-85, BUT, if i take my foot off the pedal from 65-75, the car starts shaking quite badly, and the shifter rocks backand forth maybe 1/2" 1".
Any advice?
I am suspecting either C/V joints in the rear axles, transmission mount, less likely but possibly engine mount, and/or drive shaft C/V joint?
HELP!
thanks a lot
dan
also, where is the best place to buy parts like these?
  • 5 weeks later...
Yip as above get the tyres changed and wheels balanced Plus get the geometry set up again as well ive just posted the geommetry settings on another post today.
Let us know if there are any further problems and ill give you the further fixes if that does not cure the vibrations
Also get the timing belt done as well it is at the better to be safe than sorry point of its life!
