Electric Mirrors & Lamp Washers Not Working
hi my ls400 is superb however ever since i bought the car the mirrors have not worked, when i press the buttons nothing happens the same goes for the lamp washers? and lastly the headlights at the front the two inner lights dont work either? i wonder if all these are on one circuit or fuse??
any ideas guys?
any ideas guys?
I'm not sure about the others ........... but the headlight washers only work when your lights are on ......... have you tried this?
Fuses for the mirrors are Radio No 2 fuse [feeds the switch] [bottom of steering column] and the DOME fuse. [under bonnet.]
Relay and headlight washer motor are at the bottom of the washer bottle.
Book says remove the fender liner, presumably the front wing liner.
The cleaner switch is also connected to the headlight control switch through the integration relay [bet you knew that!] whatever that is.
The pic of the headlight cleaner switch also shows terminal 6 " from TAIL LH or PANEL fuse, think that is only for the switch light.
Hope this of some use :huh:
Book was w/shop manual.
There are three, expensive and complex, but first fix you get from them pays
for them.......
If you want them try Chris Shipley
cheers ;)
