Cig Lighter
Can someone plse help
Fuse has blown for my cig lighter i cant seem to find it is it under the bonet or in the paseners side panel
what voltage?
Kind Regards
The fuse you are looking for is drivers side footwell :D or drives side panel :D
what voltage?
Kind Regards
what rate fuse please
Kind Regards
Not sure of the exact fuse or voltage :hehe: but its in where i said :D is it not on the panel that you take off to get at the fuse ?(look on the back of panel) take fuse out one by one to see if it has blown, it should say on the fuse what it is.
Thank you ill go and look now
Kind Regards
Ok guys ive looked in the fuse compartment in the door well
very hard to get the fuses out so does anyone know which one it is saves me strugling to take them all out
Kind Regards
Usually a little white pair of tweezer things in the box to get the fuses out
Fuse you need is 15Amps! :D
How do I know? I've just blown mine!!! :hehe:
I wish i would have read the reply to my post properly after taking all the fuses out of the passengers side to find out i was looking in the wrong compartment i can confirm it second 1 up ind the middle of the 3 rows
i havent changed it yet as i have no spare BUT does this fuse work the left lights on buzzer as my buzzer has stoped since i blew this fuse i do hope so
Kind Regards
  • 2 years later...
are you sure its a 15amp, i'v looked at the diagram and the second from bottom in the middle column says 10amp
Fuses are colour coded
Smokey brown color - 7.5Amp
Red - 10Amp
Blue - 15Amp
Yellow - 20Amp
Green - 30Amp
