Is200 Hid Headlights On Ebay
Unit, Headlamp, LH
GXE10, JCE10..RHD W(Discharge Headlamp)
81170-53050-
Prod. date 0107-0308
Unit, Headlamp, RH
81130-53050-
I see no headlamps that are JCE10-specific, but there are several GXE10-specific ones.
I've also noticed that the GXE10 headlamps from 9901-0207 (81170-53030/81130-53030) can be replaced with those from 0207-0308 (81170-53090/81130-53090).
I've asked the seller for the part numbers, that'll be a big help.
if they do fit an IS200, i would be intrested in buying these, as my IS light casing is all dull yell and passenger side steams up now and then..
He's also based in Huddersfield, where i work, so i can pick'em up and save on postage cost.
will have to purchase the bulbs tho.. whats the cost of these?
had a word with lexus parts department, was told the lights itself fit, but the wirring etc will not be comatible, apparently the IS300 is wired up differently to the IS200.. so it's a no no..
anybody know if these lights come with the ballasts? whats that black box thats connected to the headlights?
i think the black box is the ballasts as is200 lights dont have the black box :D i think you better getting HID kit for your is200 imi :D
These are not a direct swap.
I did the conversion on my old IS200. The units are a different size, and require modifications to both the deadlamp units, the front of the car, and the inner wings.
You also have to chop wires to get levelling going.
It is by no means an easy job.
Had an e-mail off the guy selling them (his name's Sid James!)
Part numbers 81170-53050 and 81130-53050 are on the boxes.
