C/l Not Working.
I know im a pain in the aris, But could someone direct me to the thread about re-programming your keys so the remote works..
I see it briefly, but now, cannot find it.
Please help...
Use the key is a right nonce
Try this,
to find the instructions to reprogramme your keys, do a search on 'central locking' or 'Key fob' -can't remember which, as I searched on both.
from memory (in steps) :-
1) open the driver's door and leave open
2) insert ignition key and then remove key without switching ignition on
3) then at 1 second intervals 'lock' and 'unlock' five times using the central locking button on the drivers door.
4) Close driver's door and then re-open.
5) then at 1 second intervals 'lock' and 'unlock' five times using the central locking button on the drivers door again.
6) Insert ignition key and switch the ignition on and then off.
7) Simultaneously press both the Lock and Un-lock buttons on the key fob.
8) Press any other button on the key fob. (The LED on the Key should flash twice)
9) The Central Locking should then lock and unlock once to confirm it has received the signal from the key.
This is only a brief description, but should be enough to programme a single key. The full instructions are available on here somewhere and also detail what to do to delete keys, if you have multiple keys, etc....
I've got a full print out of the instructions at home. If you don't have any luck finding them on here, I'll bring them into work tomorrow and type them in word-for-word. (Unfortunately, I don't have a PC at home.)
HTH
Andy
