Quick Question
Bazza
when i click a link
or open a new page
all i get is a small window open 3" x 3"
how can i get a full window to open ???
have tried resizing and pressing maximise buttons, but every time it opens a small window appears !
most annoying
help !!
You need to open a new link.
Then manually Re-size the box with the mouse ......... (don't press maximise)
Then when you do it again ............... it should remember the last "re-sized" frame
Did that make sense?
Bazz - if you right clck on the taskbar at the bottom of the screen and click on "Cascade Windows", this will resize all your windows to a uniform size so that every time you open another, it will open to the uniform size.
Hope this helps
