Constant Knocking Noise
GAZ-MAN
Check the shockers as well. im dont know much about the IS200 but in other cars a knocking noise on every bump and grid in the road that does your head in can often be the shocker. a simply way to test a shocker is check to see if their is alot of bounce. it should bounce once or twice... anythin more its an obv sign.
I have this problem with the RX. Everybody said drop link . Fitted a new drop link but that wasn't the problem. New top mount being fitted tomorrow. I will let you know how it goes.
Top mount was £61.00
well since that time i replaced all my standard shockers and bought a tein set up from e bay exact same problem except bit louder would i jus buy a set of new standard top mounts or does it have to be special one's cause its the tein coilovers??
