I'm thinking about installing an LED braking light that flashes (probably illegal) during hard braking on a MK2 GS300. Does the brake pedal have a position sensor which I could tap in to? Perhaps if anyone has a wiring diagram they could check for me. The only other methed I could think of detecting a hard braking situation is to make some sort of g-force sensor using a spring and contacts (very Heath Robinson).
Martin
It has possibly got a sensor buitlt into the brake booster but i wouldn't recommend messing with it as the whole system is electric and it would be quite easy to cause some major damage.
You might like to know that a new brake booster is about £2000!!!!!!!! :blink:
it doesn't have a position sensor, only the normal switch that detects if the pedal is pressed or not. I guess you could mount another switch and adjust it to only come on when the pedal was pressed down a long way.
If you have a 2001+ model with brake assist then you could probably feed into that although the brakes have to be pressed very hard for BA to activate.
The vehicle already has a g-force detector for the VSC but would be very difficult to communicate with that.
It's possibly available on ODB-II but it wouldn't be a standard reading so you would need a Toyota/Lexus reader.
Not sure how brake assist detects emergency braking - I guess there is a pressure sensor in the braking system, that could be used.
