Going For Gold...
GALLA_4
@ Owen,
Love that engine cover.. B) , looks really well, best of luck
Just a suggestion, could you try and straighten up the wires in the earthing kit abit more, give it a more perfect look...I have always thought right angles look better than curves when wiring ....IMHO :blush:
Your having a laugh right :unsure:
  • 2 months later...
Wash all the crap and dirt off them. I used a degreaser and rinsed them all off. The I took a very fine sandpaer to them. Wet and dry 800 grit would do.
Then I used a plastic primer (about 2 coats) left to dry, and it really is up to you what colour you want to go for after that. Plasticoat do some nice colours!!
Once I had painted all the bits I left them all to dry for a few days, and then came along with some clear coat lacquer and gave them all a few light coats.
Simple!!!
Simple!!!
Thanks for the help
picked up all the above today
got a nice :shutit: colour for the bit's in the bay :D
I've got a bead blaster at work so that will make the sanding part a bit quicker :)
