Rear Bumper Removal
Blum
if you are talking about the normal is200, then i will do a write up on how to remove the rear bumper - i have done mine for the rear sensors ages ago - it will be from memory but its not hard at all - you will need tools!
will do the write up after work this eves and will post it in the workshop section.
regards rob.
Yes Rob, It will be a 2003 IS200se auto.
It will be a company lease car so I dont really want to drill holes in it. Delivery sometime (early) new year!!!!
Finding this website confirmed my choice of car, very friendly, very imformative.
ok as you dont want to put holes in the bumper ( dont blame you) then forget about the quanan ones - you could go for the stick on type but it will look poo - best to go for the ones which you place behind the bumper - in that case i dont think you need to remove the bumper, would just be a case of removing one of the rear light units and feeding the wire up under the bumper and thru the light harness grommet ( that way you do not need to drill a hole) removing the light involves removing 2 screws and pulling a little bit - owners manual shows you this.
If you would still me to type something out for you let me know.
rob.
