Audio Problem
does it come from both speakers? Sounds like you have damaged the speakers.
yeah i thinks its from both.
how did i damage them? i did not do anything to them?
how do i fix it?
now ive installed new speakers my high level rear brake light vibrates on the rear window, could it be that ??? i put a thick piece of rubber there to stop it
Could be the brake light. Try driving without the radio on to see if it vibrates.
If not then the bass from the speakers could actually be making the light vibrate if it's slightly loose. Try wedging it with something (like rubber as you've said) and see if the noise goes away.
Chances are that now you have replaced the speakers and the vibration is still there that it is the brake light. Or it could be any of the plastic trim around the window. My Mondeo I had a few years back had the same problem when I put some bigger speakers in, and to solve the problem I had to remove all the trim from the inside of the window. Suffice to say, it didnt look good or stay off for long, and I wouldnt advise doing it on a Lexus!
  • Topics
  • Our picks
    • All-new Lexus RX: luxury expressed in interior design simplicity
      Lavish details and flourishes are not necessarily the best way to express luxury. A “less is more” approach with design simplicity can be a much more effective way to communicate high quality, as witnessed in the interior of the all-new Lexus RX
      • 0 replies
      • 0 replies
      • 0 replies
      • 0 replies
      • 0 replies
