Any Recommendations
el_gencer
Myself id chuck all the bits and bobs in the boot and drive down to TDI or somewhere where they know what there doing and have done the job before,rather than a Lexus main dealer the hourly rate wont be much difference what with Lexus changing around £100 a hour.If its the first time a main dealer as done the work it might take them longer in the long run ;)
If the garage knows or have done that sort of work before they should be able to get the geometry the same day as fitting.
Chips..
:excl: With the EDFC its got to connected right first time or they could damage something when fitting the servos to the strut tops.Tein on there main uk website should have a list of authorized dealers :winky:
http://www.tein.co.uk/
Chips..
it maybe a trip down to tdi. i've tried getting in touch with tdi north, but when i rang i was told to email them so i did (twice) and haven't gotten a response. i dunno maybe they are busy with stuff.
as you say chips, the edfc does need installing properly and i would like a garage that has installed them before to do the job. i'd feel more happier know that the installer has installed the system before.
PM Mark, he should be able to get you in contact with TDI North
  • Topics
  • Our picks
    • All-new Lexus RX: luxury expressed in interior design simplicity
      Lavish details and flourishes are not necessarily the best way to express luxury. A “less is more” approach with design simplicity can be a much more effective way to communicate high quality, as witnessed in the interior of the all-new Lexus RX
      • 0 replies
      • 0 replies
      • 0 replies
      • 0 replies
      • 0 replies
