Gs300 Spark Plugs
IanCornwall
Hi there everyone
before i delve under the bonnet and possibly take off the wrong cover, does anyone have any help on changing spark plugs on my GS300 etc, I am told that you have to remove sensors etc to get to some of them, also I follow a link from google that tells me somewhere on the board is a photo link showing where these are and what to do
I am dumb cause i cant find it
Any help anyone ?
remove the air box piping to the throttle body, then take off the throttle body 2x 12mm bolts at the top and 4x 12mm nuts on a bracket at the bottom. Put a rag under the throttle body as when you remove the coolant pipe it will leak, slide off the throttle body. Using a 6mm allen key undo the cover at the front and the back of the block this will expose the plugs and leads, then simply change the plugs. Denso Irridium IK16s for the GS.
  • 1 month later...
