Slight Flat Spot At About 1800 Rpm Is 300
xqj18
What fuel do you use, have you run a fuel system cleaner though recently?
Does it do it all the time or just when cold/hot?
Thanks for your reply
I use normal unleaded and have not run any type of fuel system cleaner ( I thought that catalytic converters meant no fuel additives could be used at all) the car is 5 years old now - I would say hot or cold makes no difference but less noticeable cold
thanks
Nick
alot of fuel cleaners are good with cats now, it wouldn't hurt running one through.
I use either STP fuel system cleaner or Forte system cleaner, (forte is hard to get hold of) both are safe for cats but if your worried have a read of the bottle, for £5 its worth a try...I normally run one through every 4-5months and engine seems to wake up afterwards and tick over smoother.
Thanks - I will
b regards
nick
I'll bet that the TB is coked up...bit of a PITA to strip down but worth a go.
Also try cleaning the MAF (air flow sensor) with good blast of contact/switch cleaner
I hate to say this but I do not know what the TB is
thanks for your reply
b reg
nick
Not sure if resetting the ECU would help but you could try that first.
http://www.lexusownersclub.co.uk/knowledge...p;id=38&c=5
Thanks - I have doen this and it seems to make a difference
b regards
nick
