Problems
alaneire
Hi all,
First time caller, long time listener.Big fan of the show etc etc
Mate has an Altez`
Engine light on and slightly down on power.
Bringing up fault code P1656 OCV Fault
Is this a common problem, whats the common cause and possible remedies?!!
Cheers for your help!
Alan
Often is the case with getting fault codes, they send you on a wild goose chase!
P1656
[39]
VVT signal
[OCV+, OCV-]
Poor output when driving high
speed
· Wiring and connector (oil control valve)
· Oil control valve
· Engine control computer
· +B2 voltage check
Something to do with the VVTi system..
