Loss Of Performance
NedFlounders
Hi all,
I have a Altezza 1999 which I have been very happy with.
However I have just recently had problems with the acceration.
When I get to 5000rpm I was used to getting put back in the seat.
But as I get to 5000rpm now it hits a bit of a flat spot and doesn't
perform like it used to. :unsure:
Has anyone got any ideas what could cause this?
Thank you
Ned... :)
have you done anything to the car recently? service/induction kit/ spark plugs? sounds like a fuelling issue. maybe give the MAF sensor and Inlet valve a cleaning and check ur air filter. try resetting ur ECU and see if that helps
I haven't done anything before hand. But have since changed the air filter and plugs.
A friend pulled the fuses for the ecu, will that reset the ecu?
I am having plans to have a cam belt change and general service and will then clean the maf at the same time. Hopefully that will help.
  • 1 month later...
We had an RS200 here in Sydney with much the same problem - car was ok unless you gave it a bootful, at which point it would 'flat spot' above 5000rpm as you have described. It turned out to be a faulty MAF sensor, and the owner ended up replacing the whole throttle body to sort the problem out.
