Have 94 Celsior ( LS400) and not sure if i have a problem, see a number of issues on this site regarding stiff steering at low revs, mine is fine, however seems very lite at speed, could the steering ECU be faulty or maybe this is normal, does it have speed sensitive steering, this ones got air suspetion if that makes any difference (certainly better handling when turned on) difficult to answer such a subjective question, its fitted with standard 16" tyres,
Oh and its just started the tapping sound from rear off nearside valve cover, after oil change, when it gets hot, is it better to stick in some thicker oil, currently synthetic 5-30.
John
