Headlight Removal Help?
dibsLPG
Decided to take the plunge and darken the Headlights (thanks to the tips and guides on here) but fallen over the first step-removing the thing? :unsure:
Trying to find the location of the remaining 2 x 10mm Bolts on the headlight please? Located the one on the top (obviously) but not sure where the other two are located please and how to gain access. Tried to search here but not had much luck on how to remove the lights yet. (Any Photos would be helpful). I do not fancy removing the whole bumper or wing… :tomato:
Has anyone done removed the Glass using a Heat Gun (softening the glue seal)? What should I look-out for or avoid please?
Do not fancy putting it in the oven (it scares me- based on my cooking skills – I will end up melting the thing and serving it up to the dog like my past exploits) :blush::hehe:
Over this long weekend and hopefully install the Halo Angel eyes (yes I now it is BMWish) but I like the look + Eyebrows since I have them opened up, Yes a big bank holiday mod is about to start. so will post picks once done or the pics of the mess that might be made. :crybaby: ]
Your help / Guidance will be greatly appreciated. :D
Heatgun takes forever, just stick it in the oven on about 120 degrees for 2 minutes at a time, constantly check them. make sure no part of the light touches any part of the oven. Put it on a piece of cardboard in the oven
Here you go amigo, for removing the heads:
http://www.lexusownersclub.co.uk/forum/ind...ove+head+lights
All the best,
J
Thanks a Lot mate, :D
Printed it out and ready to give it a go.
I and still nervus to pop it in the oven but if the heat gun trick does not work then i shall try the oven.. What is that in Gas Mark please since mine has no temp setting on the old log burner.. :blink:
Dibslpg
