Heater Playing Up
DaveRS200
below steering wheel is a small grille on the LH side - behind this is the temp sensor - check if that is clean
do u have your heating set to AUTO or do u have the fan set to I or II?
ok il check it. na i dont have it set to auto just set it to high or low.
i dont get how the auto setting works because when eva i set it to auto it blows alot of air out.
thanks mate
the ambient temp sensor in the little grill as mentioned above !
9 out of 10 times its been un plugged when someone has removed the panel
my car had exactly the same problem and that was the cure !
its only 3 screws so tale it off and have a look !
also make sure that the tube to it is open and kink free !
