Help Im Gonna Cry!
Arqum
remove the headlight and turn on it's side is what i'd do.... you can get pick-up devices in motor shops that might work depends on how much access you have and if you can see the bulb
one of these ....
when i used to build headlamps we used a piece of stiff wire with a blob of sticky putty on the end to remove any foreign objects from inside the lamps maybe worth a try as you can feed it through the main bulb hole and keep bending it till you can get it stuck to the sticky stuff you could probably try using chewing gum on the end if you have no putty just put a small bend in the end of the wire so it holds the putty better??
knowing my luck the putty will fall in too!
:lol::lol: if you put a hook shape on the end of the wire and wrap the sticky stuff round it, It should stay on and if you do use chewing gum you can wrap that round loads of times :D its a shame your not closer matey as i could probably get it out for you without removing the lamp as i've done it on mine in the past :whistling::lol:
