Warning Light
justinam
Hi i have a IS220SE and its done about 6000miles and the oil maintance warning light has come on, my nearest dealer is about 30miles away, is there some way of reseting it on the dash without going to main dealer. many thanks.
  • 4 weeks later...
did you have it from new ,how old is it and is there any service history to date.
  • 1 year later...
if its done to reset it you just hold the trip switch then press the start button (without the clutch down) you will see the odometer count down then zero itself. job done
Have the same problem and tried this. Doesn't work. Any other suggestions???
:crybaby::crybaby:
:crybaby::crybaby:
it tells you how to do it in your hand book
  • 1 month later...
