Dashboard Lights
Can anyone please help? I have a 54 plate IS200 Sportcross with a dash board lights fault. All the lights stopped working a couple of weeks ago and can't find the problem, the items I have checked are listed below. At the same time the rear fogs have stopped working though the light bulbs are fine.
All fuses i can find (both sides inside the car and under the bonnet) are working fine
The Rheostat is still working on the radio & air con displays
Replace rear fog switch, still the fogs and dash lights will not work.
All the dash bulbs have been checked and are ok
Any ideas?
The rheostat was the first thing that i tried, i have since noticed that turning it has no effect on the radio or heater display so i may try taking it out to see if it is faulty. I still can't understand why the rear fogs wouldn't work though
