Need Help Will Thease Wheels Fit My Is200
kris_t
from the wheel/tyre guide on Stav's link
PCD = 114.3mm Offset = 45mm
19" upgrade f/r =19"x8"
19" upgrade f/r = 235/35-19
(A -25mm drop is possible with these combinations)
With 19's don't run any rim bigger than 8" on the front as it will hit the strut.
19's will rub on the front inner arch at full lock, but this can be solved by cutting or bending away some of the plastic trim.
