Best Place To Put....
Fidgits
Right... I have a snooper S5R, and have tried to work out the best place to put it.
The manual says it has to be level, and not be obstructed by the wipers...
It is currently sitting on top of the dash tray (where the sat nav isn't :crybaby: ) but think it looks a bit obvious...
Can anyone reccomend a better place to put it (considering the wires to the lighter)
Ian.
I have mine in between the dash tray and the main dials (you may have seen it at Cotswold).... and I have run the wire down the side of the centre console so you can't see it.... I'll show you at Japfest if you like?
Thanks Zee... I'll take a look
