Hello,
I'm looking at putting a set of the standard 17" IS250 wheels on my altezza.
What are the wheel widths that they came in? They appear to be staggered judging by the offsets.
Nathan
Nathan,
Sorry, answered your PM before reading your post. The only mod you have to make in fitting the 250 17" wheels on the Altezza is to lightly grind or file the raised lug on the front suspension member (the vertical bar directly behind the wheel). The lug is exactly aligned with the rim of the 17" wheel and most probably will foul. It's certainly too close for comfort. The 8JJ wheels from the early 250's and the 8.5JJ from the later models both fit without problems. The wheel width is cast in a spoke of each wheel so you'll need to check the size.
