Trc (traction Control)
kobz-lexus
The TRC light shouldn't have anything to do with coil packs. As Tomo said, try an OBDII reader if you can (available from eBay) to check the diagnostic codes.
Does the "TRC OFF" light flash all the time ? If so, the implication is that there's either something wrong with the TRC itself, or possible the TRC OFF switch.
