Auto Door Locking Function?
Stevie C-D
Hi Mr/Miss Aquanuke
20mph would be fine (anything 1+ mph really, Lexus say it's 13mph) or even doors lock when lever moved from Park to another range. If you have doors unlock when placing vehicle into park that would also be of help.
Many thanks
Stevie
Theres quite a few options depending on what you prefer.
Mine is set to
AUTO LOCK - Function to lock the doors when the vehicle reaches a certain speed
Or if you prefer theres,
LOCK/SHIFT BRKE -
OFF: Doors remain unlocked when shifting from PARK range to anther range after releasing the brake.
W/O STP: Doors lock when shifting from PARK range to another range.
W/STP: Doors lock when shifting from PARK range to another range after releasing the brake.
and then you want this one as well..
UNLOCK/ PARK -
Function to auto unlock all doors when vehicle is shifted into Park and ignition ON.
Full list can be found here
http://209.85.229.132/search?q=cache:_yERl...lient=firefox-a
Just make a note of what you want and get your local Lexus dealer to enable it, they will do free of charge.
Hi, thanks again.
I have tried my local Lexus dealer (Chester) spoke to the guy in the service department and he said this was not available to UK Lexus owners but he was willing to organize some Yank add on for £1000 ish. So I tried emailing Lexus UK for advice and I am still awaiting a reply. May have to approach a Lexus independent garage at this rate.....all she want's are the doors too lock as she moves off the same as her old SLK.. :(
